NAA v12.0 Upgrades: File System 0-CreateSchema Job Taking Longer Than Usual? Here's Why!
Hey everyone,
If you’ve recently upgraded Netwrix Access Analyzer (formerly Netwrix Enterprise Auditor/StealthAUDIT) from v11.6 to 12.0, and you notice the File System 0-CreateSchema job is taking much longer than you’re used to – don’t worry, you’re not alone, and it’s actually expected.
:light_bulb: What’s going on?
As part of the upgrade from v11.6 to 12.0, there’s a new analysis task “18. Data Migration” on the 0-CreateSchema job that:
  • Moves IDs and metadata from the SA_FSAA_Resources table into new, better-organized tables
  • Cleans up mappings in SA_FSAA_Trustees and SA_FSAA_Gates, filling in any missing values with safe defaults
This process helps lay the groundwork for a cleaner, more efficient system — but in environments with a lot of File System data, it can take 12 hours or more to complete.
:white_check_mark: What should you do?
To let the process run smoothly:
  1. Schedule the File System 0-CreateSchema job (no trigger needed)
  2. Temporarily disable other File System jobs under the Scheduled node
  3. Right-click 0-CreateSchema in the Schedules node and select Run
  4. After it completes, re-enable the other File System jobs
:eyes: Still concerned?
If things feel off or you just want some peace of mind, feel free to open a support ticket via the Netwrix Customer Portal. A Support Engineer will be happy to take a look and make sure everything’s moving along as it should.
Hope this helps – and if anyone else has gone through the upgrade from NAA v11.6 to 12.0 and has tips or feedback, feel free to share below!
More information on this can be found in our Help Center here:
Extended Runtime for 0-Create Schema Job Post v12.0 Upgrade
