Managing NTFS Permissions with PowerShell
This comprehensive guide covers all aspects of NTFS permissions management using PowerShell.
Prerequisites
If you’re not familiar with NTFS permissions management, check out the NTFS Permissions Management Best Practice guide.
Setting File and Folder Permissions
To implement a least-privilege model (best practice for system security), IT specialists configure NTFS access control lists (ACLs) by adding access control entries (ACEs).
Listing Available Permissions
Find all available user permissions:
[system.enum]::getnames([System.Security.AccessControl.FileSystemRights])
Setting Permissions
The PowerShell Set-Acl cmdlet is used to change the security descriptor of a specified item.
Grant Full Control
$acl = Get-Acl \\fs1\shared\sales
$AccessRule = New-Object System.Security.AccessControl.FileSystemAccessRule("ENTERPRISE\T.Simpson","FullControl","Allow")
$acl.SetAccessRule($AccessRule)
$acl | Set-Acl \\fs1\shared\sales
Note: SetAccessRule completely overwrites the permissions for a user or group.
Add Permissions (Without Overwriting)
$acl = Get-Acl \\fs1\shared\Accounting
$AccessRule = New-Object System.Security.AccessControl.FileSystemAccessRule("ENTERPRISE\J.Carter","FullControl","Allow")
$acl.AddAccessRule($AccessRule)
$acl | Set-Acl \\fs1\shared\Accounting
Use AddAccessRule to add permissions without overwriting existing ones.
Permission Types Reference
Individual Permissions
Access Right PowerShell Name
Full Control FullControl
Traverse Folder / Execute File ExecuteFile
List Folder / Read Data ReadData
Read Attributes ReadAttributes
Read Extended Attributes ReadExtendedAttributes
Create Files / Write Data CreateFiles
Create Folders / Append Data AppendData
Write Attributes WriteAttributes
Write Extended Attributes WriteExtendedAttributes
Delete Subfolders and Files DeleteSubdirectoriesAndFiles
Delete Delete
Read Permissions ReadPermissions
Change Permissions ChangePermissions
Take Ownership TakeOwnership
Permission Sets
Access Rights Set Rights Included PowerShell Name
Read List Folder/Read Data, Read Attributes, Read Extended Attributes, Read Permissions Read
Write Create Files/Write Data, Create Folders/Append Data, Write Attributes, Write Extended Attributes Write
Read and Execute Traverse folder/Execute File, List Folder/Read Data, Read Attributes, Read Extended Attributes, Read Permissions ReadAndExecute
Modify All of above + Delete Modify
Copying Permissions
To copy permissions, a user must own both the source and target folders:
get-acl \\fs1\shared\accounting | Set-Acl \\fs1\shared\sales
Exporting Permissions to CSV
For a detailed guide on exporting NTFS permissions to CSV, see this how-to.
Removing User Permissions
To remove permissions, use the RemoveAccessRule parameter.
Remove Specific Permission
Delete the “Allow FullControl” permission for T.Simpson:
$acl.RemoveAccessRule($AccessRule)
Note: RemoveAccessRule deletes only specific permissions.
Remove All Permissions for a User
To completely wipe T.Simpson’s permissions, use PurgeAccessRules:
$usersid = New-Object System.Security.Principal.Ntaccount ("ENTERPRISE\T.Simpson")
$acl.PurgeAccessRules($usersid)
Important Notes:
  • PurgeAccessRules doesn’t work with a string username; it works only with SIDs
  • We used the “Ntaccount” class to convert the user account name into a SID
  • PurgeAccessRules works only with explicit permissions; it does not purge inherited ones
Enabling and Disabling Permissions Inheritance
NTFS permissions can be either explicit or inherited. Inherited permissions are inherited from the parent folder.
Permission Hierarchy
  1. Explicit Deny
  2. Explicit Allow
  3. Inherited Deny
  4. Inherited Allow
Managing Inheritance
Use the SetAccessRuleProtection method, which has two parameters:
  1. First parameter: Blocks inheritance from parent folder ($true or $false)
  2. Second parameter: Retains or removes current inherited permissions ($true or $false)
Disable Inheritance and Remove Inherited Permissions
$acl.SetAccessRuleProtection($true,$false)
All inherited permissions are removed; only explicit permissions remain.
Re-enable Inheritance
$acl.SetAccessRuleProtection($false,$true)
Changing File and Folder Ownership
To set an owner for a folder, use the SetOwner method.
Change Ownership
Make “ENTERPRISE\J.Carter” the owner of the “Sales” folder:
$object = New-Object System.Security.Principal.Ntaccount("ENTERPRISE\J.Carter")
$acl.SetOwner($object)
We used the Ntaccount class to convert the user account name from a string into a SID.
Requirements
The SetOwner method does not enable you to change the owner to any account you want; the account must have:
  • “Take Ownership” right
  • “Read” right
  • “Change Permissions” right
Complete Examples
Example 1: Grant Modify Permission to a Group
$path = "\\fs1\shared\ProjectFiles"
$acl = Get-Acl $path
$permission = "DOMAIN\ProjectTeam","Modify","Allow"
$accessRule = New-Object System.Security.AccessControl.FileSystemAccessRule $permission
$acl.AddAccessRule($accessRule)
$acl | Set-Acl $path
Example 2: Remove All Permissions for a User and Set New Ones
$path = "\\fs1\shared\sales"
$user = "ENTERPRISE\J.Smith"
# Get current ACL
# Remove all existing permissions for user
$usersid = New-Object System.Security.Principal.Ntaccount($user)
# Add new ReadAndExecute permission
$AccessRule = New-Object System.Security.AccessControl.FileSystemAccessRule($user,"ReadAndExecute","Allow")
# Apply changes
Example 3: Disable Inheritance and Set Explicit Permissions
$path = "\\fs1\shared\Confidential"
# Get ACL
# Disable inheritance, keep existing permissions
$acl.SetAccessRuleProtection($true,$true)
# Remove all non-admin access
Get-ADUser -Filter * | ForEach-Object {
  $usersid = New-Object System.Security.Principal.Ntaccount("DOMAIN\$($_.SamAccountName)")
# Add admin full control
$adminRule = New-Object System.Security.AccessControl.FileSystemAccessRule("BUILTIN\Administrators","FullControl","Allow")
$acl.AddAccessRule($adminRule)
# Apply
Example 4: Bulk Permission Assignment from CSV
path,user,permission,type
\\fs1\shared\HR,DOMAIN\HRTeam,Modify,Allow
\\fs1\shared\Finance,DOMAIN\FinanceTeam,FullControl,Allow
\\fs1\shared\IT,DOMAIN\ITTeam,Modify,Allow
$permissions = Import-Csv "C:\permissions.csv"
foreach ($perm in $permissions) {
  $acl = Get-Acl $perm.path
  $accessRule = New-Object System.Security.AccessControl.FileSystemAccessRule(
    $perm.user,
    $perm.permission,
    $perm.type
  $acl | Set-Acl $perm.path
  Write-Host "Applied $($perm.permission) for $($perm.user) on $($perm.path)"
Best Practices
  1. Test First: Use a test folder before applying to production
  2. Backup: Export current permissions before making changes
    Get-Acl \\fs1\shared\sales | Export-Clixml C:\backups\sales-acl.xml
  3. Use Groups: Assign permissions to groups, not individual users
  4. Least Privilege: Grant only the minimum permissions needed
  5. Document: Keep records of permission changes
  6. Audit: Regularly review permissions
  7. Inheritance: Use inheritance when possible for easier management
Troubleshooting
Common Issues
“Access Denied”
  • Solution: Run PowerShell as Administrator
  • Ensure you have “Change Permissions” right on the folder
“Cannot find path”
  • Solution: Verify path exists with Test-Path
  • Use UNC paths for remote shares
Changes Don’t Apply
  • Solution: Check if Group Policy is overriding settings
  • Verify inheritance settings
Viewing Current Permissions
# View permissions in readable format
$acl = Get-Acl "\\fs1\shared\sales"
$acl.Access | Format-Table IdentityReference,FileSystemRights,AccessControlType,IsInherited -AutoSize
Next Steps
Related Topics
