Issue with Directory Manager
Hello all, I have an issue with Directory manager, especially on the GroupID Portal, and I dont know how to debug it.
When I try to create any object (user/group/contact), the first steps are OK, but when I click on the last page, there is nothing on the summary, and I cant finish the wizard…
There is no error, just nothing.
I do not understand how to debug it, I already try to add the website on the Trusted Sites.
Any tips ?
Regards
Hello Benjamin, Welcome to Netwrix Community!
What version of Identity Manager are you using?
When did you start experiencing the issue?
Cheers
Hello, thanks for your answer.
The version is the last one : 11.1.25134.03
I just deployed the solution, the prerequesites was successfly deployed, no issue when deploying the app Group ID Portal, but since the install, I was not able to finish the wizard
I’m sorry for the trouble you’re encountering. It might be browser-related or due to security settings.
Please try another browser. If that doesn’t resolve it, consider submitting a ticket via our Technical Support portal.
Hello, I already try with Firefox with the same issue. I’ll open a case asap
Thanks :slight_smile:
Hello Daanish, for information, the issue was the language of the browser. We changed the language of the browser from French to English. GroupID v.11 only supports English language for now and the feature to support other languages is part of the product’s road map.
Maybe this will help someone :slight_smile:
Regards
Hello Bejamin, Thanks for the update. This would certainly help in fixing the issue in the product.
