About This Guide
This guide serves as a practical command-line reference for configuring Cisco routers and switches, covering everything from VLANs and NAT to SSH access, routing protocols, and troubleshooting. Whether you’re just learning Cisco IOS or managing complex environments, you’ll find the essentials to speed setup, enhance security, and respond to common issues.
Introduction
The Cisco IOS (Internetwork Operating System) provides admins with the means to manage and configure Cisco devices. While Cisco’s command structure is proprietary, it exemplifies fundamental concepts in network device management that are applicable across various vendors. Similar command-line interfaces (CLIs) and configuration principles can be found in systems from other major networking companies like Aruba, Juniper and Broadcom, allowing network professionals to apply their skills across different platforms with some adaptation.
This article provides a cheat sheet that you can use as a quick command guide for managing and configuring Cisco network devices. Console output examples are provided to show some commands step by step in action; they were captured using a console connection to the router or switch.
Table of Contents
CLI Fundamentals
Switching and VLANs
Networking
Operations
- Troubleshooting and Diagnostics
- DHCP Configuration
- Monitoring and Logging
- Backup, Restore and Upgrades
