Increase delay between SQL connection retry attempts
Add a longer delay between retry attempts to reduce failures caused by transient SQL connection errors.
During processing tasks, transient SQL connection errors can occasionally occur due to temporary network issues. The current retry logic immediately performs two retries in quick succession (less than one second apart), which often fails to mitigate the issue:
Microsoft.Data.SqlClient.SqlException (0x80131904): A transport-level error has occurred when receiving results from the server. (provider: TCP Provider, error: 2 - Connection was terminated)
Add a longer delay between retry attempts would increase the likelihood of a successful reconnection when a transient issue is involved.
It is necessary to restart the job execution manually.
Hi @raphael Thanks for the feedback! We’ve added a ticket for this improvement, and we’ll update this post as it moves through the process. :slight_smile:
