Improvement for configuration deployment : Force Cascade Delete
Major bug : configuration deployment : Force Cascade Delete
We think there is a problem with the --force-cascade-delete option during configuration deployment.
Over the past few years, we’ve faced recurring problems when deleting Properties in our Person and PersonRecord EntityTypes. We make a conscious effort to reuse TargetColumnIndices (TCIs) whenever possible.
We’ve observed 2 specific issues:
— Although the TCI appears to be available in our configuration, the deployment fails with a “duplicated TCI” error.
— When reusing a recycled TCI (often for boolean properties), the newly created property — which should not have been initialized after deployment — appears as already checked in our workflows.
The --force-cascade-delete doesn’t purge the database of old values.
This regularly block our PRODUCTION deployments.
We play around with TCIs until deployment succeeds. It is a major inconvenience.
Hi @ma.ra ,
Have you contacted the support team with this issue ?
Hello @ma.ra ,
Maybe you can try looking at the Usercube-Manage-History.exe.
Usercube-Manage-History | Netwrix Product Documentation
Maybe this could unblock it but it is far-fetched. A support ticket would be the best.
