Impact Of Remove If Orphaned On Directories
Hello everyone,
I have a question regarding the “Remove If Orphaned” option under the resource types for Directories.
When we select the “Remove If Orphaned” option, should this remove all the Identities in the directory that do not have an assigned owner? Or will the current Identities without an owner remain, and only those that lose an owner after applying the option be removed?
Hi Kamil,
When “Remove If Orphaned” is checked Usercube generates a deprovisioning order whenever the Owner is deleted.
This is useful in 2 cases:
  • Delete a target account if the identity is removed in Usercube (not just archived)
  • Trigger the departure workflow when a uses is deleted in the HR source
It applies only to events detected after setting the option.
