How to Create a Show & Tell
So you have something cool you want to show off in the community? Let’s post it! Think of the Show & Tell category as an area where you can share something unique that you did with the product or a resource that you created! If you find yourself constantly sharing the same process or guide over and over, it sounds perfect for a Show & Tell!
What is a Show & Tell?
We ask that the Show & Tell be more on the technical side of things. Really get into the weeds of the solution—include code snippets, screenshots, videos, reference docs, etc! These should not just be a quick paragraph with a line of code or some hidden checkbox that people often forget about. Describe the problem—describe the solution! Think of the adage: Don’t give them fish, teach them how to fish. We want readers to leave this Show & Tell knowing why the solution worked.
How do you make one?
  1. Find the right Show & Tell category
Product Link
1Secure 1Secure > Show & Tell
Access Analyzer Access Analyzer > Show & Tell
Activity Monitor Activity Monitor > Show & Tell
Auditor Auditor > Show & Tell
Change Tracker Change Tracker > Show & Tell
Data Classification Data Classification > Show & Tell
Directory Manager Directory Manager > Show & Tell
Endpoint Policy Manager PolicyPak > Show & Tell
Endpoint Protector Endpoint Protector > Show & Tell
Identity Manager Identity Manager > Show & Tell
Identity Recovery Identity Recovery > Show & Tell
Password Policy Enforcer Password Policy Enforcer > Show & Tell
Password Secure Password Secure > Show & Tell
PingCastle PingCastle > Show & Tell
Privilege Secure Privilege Secure > Show & Tell
Platform Governance for NetSuite Strongpoint for NetSuite > Show & Tell
Platform Governance for Salesforce #platform-governance-salesforce:show-tell
Threat Manager Threat Manager > Show & Tell
Threat Prevention Threat Prevention > Show & Tell
  1. Select + New Show & Tell
  2. And now that the text editor is up, let the show & tell magic happen! :magic_wand:
Enter an enticing but accurate topic
Think of the title as a marketing headline that should to catch a reader’s attention. If you know the content ahead of time, go ahead and make a title. Sometimes, though, it’s easier to create a title after you’ve written the content.
:double_exclamation_mark: Don’t worry, you won’t be able to submit a topic without a title.
Select appropriate tags
The search function will catch keywords in your Show & Tell, but tags will also help boost findability. Tags should only be a few words, but try capturing the problem, tools, or solution that are your Show & Tell addresses.
Write the content
The general gist should be:
  1. Overview: Here is a problem that people often face
  2. Description: Here is my solution and why/how it works
As noted above, we encourage you to roll your sleeves up and get technical—I assure you that’s what others in the community want to see! Share the code or include screenshots along the way. While writing, remember that the reader may be unfamiliar with this area, so be a little more thorough or descriptive.
Set it as your Featured Topic
If you’re extra proud of your Show & Tell, you should set it as the Feature Topic on your profile! That way, if someone is browsing your profile, they’ll see what you made!
  1. First, navigate to your profile settings
  2. Scroll down to the Featured Topic section, and click Select a New Topic
  3. In the pop-up, paste the URL to your Show & Tell (or search for the title if you don’t have the URL handy)
  4. Hit Save
  5. At the bottom of the page, hit Save Changes
And just like that, your Show & Tell is now a headliner on your profile page! :smiling_face_with_sunglasses:
