How to add criteria to scalar rules
Hello Everyone,
Is it possible to add additional criteria for the scalar rules in the UI?
I have created multiple dimensions and added them to the DisplayEntityType, example D3IsActive=“true”. This does not add an additional criteria in the scalar rule, while it does for the resource type, Roles and even navigation types.
Does it need to be specified differently for scalar rules or are only single rules allowed as criteria there?
Hi Kamil,
You cannot add extra criteria to scalar rules.
You have to possible ways:
  • Use Single Roles.
  • Include the criteria in the C# expression of the scalar rule (might a bit heavy)
Regards
Hazem
