FS_FileTagging job aborts after completion
“Unknown item type: TSPADOJobTaskStatisticsThread.TAbortParam”
Description
Summary
  • FS_FileTagging (Add Tags) job starts and runs normally.
  • The job reports successful completion .
  • Immediately during job stop / statistics processing, the following error appears:
    ”Unknown item type: TSPADOJobTaskStatisticsThread.TAbortParam”
  • After that, the job queue is aborted and terminated.
  • Logs repeatedly show “ WaitIfPaused “Waiting on job engine Done” “ before the abort.
Notes
  • The error occurs after job execution, not during file processing or tagging.
  • Source tables and RowKey configuration are correct.
  • This appears to be a job engine / queue handling issue, likely related to version or hotfix mismatch or residual job state.
Question
Has anyone seen this error with FS_FileTagging or other Action module jobs, and is it a known version compatibility issue?
Thanks for reaching out. I have not seen this issue in particular and do not see any hotfixes related to this issue. I do see that you have noted the job reports successful completion but i’d ask to confirm whether the actions taken (designed by the action module) have successfully completed in the target environment. This would help us determine if it is indeed an error with the action module or the some other function of the job itself.
Additionally, if further investigation is needed, please do not hesitate on reaching out to support to raise a support ticket, if one has not been raised already.
