Expand possible event detail fields for use as query filters
More Event Details fields in query filtering
When creating a new investigation, not all fields visible in the event details are available for use as filters in creating queries.
For example its not possible to query over:
Originating Client Protocol, Client IP, Host IP and more.
Was not able to find workaround for lack of this functionality.
Hi Bartłomiej! Thanks for joining the community.
Can you just verify which version of the product you are on? Also, you included the three fields as examples - are there others you could see yourself wanting or needing to query?
Thanks!
