The honey token threat detector should ideally be disabled by default out-the-box since it requires extra configuration.
Due to the extra configuration requirements to utilize the Honey Token threat detector properly, it would make more sense to ensure it is not running by default (without extra configurations in place) to help with application performance (and because its not adding value without a honey token already being in place). In fact, it might be even better if we could force the logic to not let it be enabled unless a honey token is already configured.
Manually disable the threat detector after install.
