Enable Content-Based Inspection for Rhino (.3dm) Files
We request support for inspecting Rhino (.3dm) files based on their actual internal content rather than relying solely on filename-based evaluation.
In our current environment, the DLP/inspection engine is unable to analyze Rhino (.3dm) files based on their internal structure or content. As a result, we can only apply controls using filename-based rules, which is both impractical and insufficient for ensuring proper data protection. Rhino models often contain sensitive design data, intellectual property, or prototypes; therefore, relying solely on filenames does not provide the security or accuracy required in real production workflows.
Enabling content-based inspection for .3dm files would allow us to apply more granular rules, prevent data leakage more effectively, and ensure that sensitive CAD/3D design files are properly protected. This enhancement would significantly improve detection accuracy and reduce false negatives for these file types.
Currently, we rely on basic filename-based filtering, which is only a partial workaround and does not guarantee real protection. We attempt to mitigate risks by combining filename rules with user/group restrictions and monitoring policies, but these methods are far from ideal and still allow potential data leakage if filenames are modified or disguised.
Hello,
Thank you for taking time to write your request.
We will investigate the current options for extending CAP coverage for Rhino (.3dm) files and will get back to you with updates. However, if you have a few sample files that our team can use for investigating/testing the scenario, please feel free to attach them here as well. It will be of great help.
Kind Regards,
Simona
Hello,
I am sharing the file types in the attachment.
Best regards
.3dm and stl file type.zip (242.5 KB)
Hello,
Thank you! Please note that our team will begin to investigate the current possibilities to cover this and it will take some time.
We will share any updates upon progress.
In the meantime, we thank you for the patience!
Kind Regards,
Simona
Hi @Yagiz57,
Good day!
We wanted to let you know that your item is still under review on our desk, and we will update you as soon as the investigation is complete. We appreciate your patience and understanding while we work through our current full agenda with high priority items.
All the best,
Simona
