Delete Domains from Domains page
Delete a Domain a much easier way
Currently, due to limited documentation a customer has to submit a ticket to ask how they can delete a domain. Customer reported that they are unable to delete domains from PingCastle Enterprise most likely due to the fact that domain already has reports.
  1. Navigate to the Infrastructure > Domains > click domain that you want to delete.
  2. In the URL address note the id of the domain you are viewing. It should be displayed after the last ‘/’.
    For example: http://localhost/Domains/Details/1 or http://localhost/Domains/Details/2
  3. Then change the URL to <PingCastle_URL>/Database/DeleteDomain/
    Where <PingCastle_URL> is your pingcastle Web UI address
    Where is the number identified from the above.
  4. You will be asked if you want to proceed. Click “Proceed” and wait for delete process to complete or fail.
There is also another way to remove details of specific domain from the Web UI details and analytics. By switching the domain status to “Removed” in the “Edit” domain settings you will hide all data related to this domain from Pingcastle Web UI:
However, this will not remove domains data from database. If you decide to attempt this I would suggest noting the ID of the domain - after using "Removed" status you wont be able to access domain in the “Domains” view, but you can still use its ID to access its edit page and bring it back to Active status - Example: /Domains/Edit/<ID of the domain that was set to “Removed”>.
We should absolutely make this available in the UX. I will put together a feature request internally to expose this and make it clear what the difference is between the status removed vs deletion of the domain.
This is now implemented as per the latest release!
