Check if “AreAccessRulesCanonical” and “AreAuditRulesCanonical” for relavant objects are true
Canonical order for permissions is important for deny or allow permissions to work as expected. If the order is incorrect, then allow permissions may unexpectedly win against deny permissions. This can lead to a security issue.
ALCs are often believed to be always like “deny always wins” wich is not true even with canonical order.
An example why that happenes:
Someone has made an example with a file :
The order should be checked for AD Objects, and for files in Netlogon/Sysvol shares, and if configured external GPO files (AD GPO Objects doesn’t always have to be linked to SYSVOL)
Privileged accounts > ACL Check > P-CanonicalOrderADObject / P-CanonicalOrderFiles
Using different Software or PowerShell scripts basically something like that:
Get-Acl -Path “AD:CN=ANYOBJECT,DC=examlple,DC=com” | Select-Object -Property AreAccessRulesCanonical,AreAuditRulesCanonical
