Create automatically credentials group based on ressource group
Currently, credential groups can only be created manually, which is time-consuming and prone to errors. Similar to the existing auto-enrollment for resources, it should be possible to automatically create and maintain credential groups.
The proposal is to generate credential groups dynamically based on managed accounts associated with a specific resource group. These credential groups could then be used in credential-based access policies.
This would allow administrators to grant access at a tier level (for example, Tier 0 servers, Tier 1 servers, or workstations), so that specific admins automatically gain access to all managed accounts within the corresponding resource group, without manual group maintenance.
Credential groups need to be create by hand and update on a regular basis.
