CREATE THE OPTION TO IDENTIFY PHONE NUMBERS FROM EL SALVADOR
It is extremely important because they are part of the sensitive information that needs to be identified with the tool, and regular expressions do not work very well.
We have reviewed your request internally and we would like to inform you that El Salvador phone numbers can actually be detected and reported with our current ‘International’ Phone Number.
Therefore, we kindly ask you to try and run a few tests by creating a Content Aware Protection Policy > where you will need to select ‘International’ from the Predefined Content > Phone Number section.
Here you can see some of the Content Aware Report results as well, where El Salvador landline and mobile phone numbers are correctly identified and reported:
I was curious if you had the chance to look over my previous message. Could you please let us know if you tried that workaround? Did it work for you?
In the meantime, we also registered an improvement for properly detecting El Salvador national phone numbers, that will be included in Content Aware Protection Policy.
However, at the very moment I cannot share any estimated delivery date, but rest assured that you will be notified about it.
