Clarification on Offline Add-on behavior in Netwrix Password Secure
Hello Netwrix Team,
We are currently implementing Netwrix Password Secure, version 26.5.1.34120, and before finalizing the solution design, we would like to clarify a few points regarding the behavior of the Offline Add-on.
The documentation for the Offline Add-on states that only the Password module is available, filters are not available, and records can be located using the search function.
Could you please confirm whether, in the current version, the offline database retains the Organizational Unit (OU) structure, for example through a tree view or an OU-based filtering option, or whether users only see a flat list of the records available offline?
We also found a UserVoice request titled “Offline Client – Strukturbaum fehlt”, which indicated that starting from version 8.13 it would be possible to filter records by OU in the offline client.
Could you please confirm whether this functionality was actually released and, if so, whether it is still available and supported in version 26.5.1.34120?
Thank you in advance for your support. We look forward to your feedback.
