Change Tracker check boxes hit box change
When selecting multiple computers in groups, you have to be very careful where you click
When selecting multiple computers to add them to another group or remove them from their current group. I go to Groups > select the group theyre in, find the computers I want to remove from that group and start clicking the check boxes. If I click directly on the box it works. But if I miss click everything gets unchecked… the most frustrating. Can we make it so if you click anywhere around the checkbox it also checks the box?
very carefully only click inside the tiny checkbox.
Upload any other supporting files that you think should be considered in this idea.
Hi Phil,
This sounds like a bug. Can you please open a support ticket and ask them to escalate to R&D per my request?
- Dan
