Having the ability to easily run database maintenance for file systems within the application.
Having this capability within in the NAA application would substantially cut down on the cumbersome process for customers to remove older file system data, duplicate entries etc. Ideally, if a new node within the NAA application was created under the global settings, specifically for database maintenance and operated similarly to the maintenance feature in our Threat Prevention application this would greatly help not only the customers but support as well.
Currently the only way to solve these issues is by completely dropping all of the file system data and running the system scans again. This method has been reported by customers as not ideal.
