Disable web form autofill for individual records
One-sentence summary of your feature request?
Disable Autofill from websites for individual records for Light User
We have the problem that a normal user often still needs to enter a Captcha or an authentication certificate when authenticating on websites.
With Autofill, the login is executed automatically, which leads to an error unless the Captcha is confirmed or the certificate file is uploaded.
This option exists in the Full Client for the Advanced User.
The Standard User doesn’t have this option.
Since such logins are unfortunately becoming more and more common, this feature would be more than helpful and convenient even for a Standard User.
We have to remove the URL from the record so that the web plugin doesn’t perform Autofill.
As a result, the user always has to search for the record manually in addition and insert the username/password via copy & paste.
Comfortable is sadly something else.
