API's for reporting purposes
API for reporting
Would like a way to use API’s for reporting features. Connected, online for specific amount of days. Agent status.
We have to manually export a list of macOS machines and sort by date to see when the workstation last checked in, if the license is valid etc.
Hi Doug,
Thank you for your request!
We understand how valuable API calls can be and are planning to introduce them in the future. However, due to current development priorities, this feature is not expected to be available in the short to mid-term.
In the meantime, depending on your needs, you might consider monitoring through manual exports or automated SIEM data queries. We’re also working on enhancing log exports to include more detailed information about computer status—this improvement is expected in the mid-term.
Kind Regards,
Simona
