Analyze Trigger Frequency with Masked Matched Items
The goal of this implementation is to enable event grouping based on a unique trigger identifier and to provide quantitative statistics on trigger activations over a defined time period.
The system should allow events to be aggregated in a way that clearly shows how many times a specific trigger (for example, Example_XXXX) was activated during a week or another selected time range, in the following format:
“Trigger Example_XXXX was activated 500 times over the last week.”
This capability will make it possible to identify the most frequently triggered (noisiest) elements without requiring access to the textual content of events, which is especially important in environments where log data is masked or access to raw logs is restricted.
Additionally, it is proposed to introduce a standard report or dashboard such as “Top Triggered Patterns”, which would display:
the trigger identifier;
the number of activations;
the selected time range,
presented purely in quantitative terms, without exposing event details or textual payloads.
Implementing this approach will improve monitoring efficiency, simplify rule tuning, and help security teams focus on the most problematic or overly active triggers while maintaining data privacy and compliance requirements.
At the moment, this challenge is handled through manual analysis and indirect indicators. We rely on overall event volume trends, partial policy-level statistics, and manual sampling over time to estimate which triggers may be generating the most noise. However, this approach is imprecise, time-consuming, and does not provide reliable trigger-level visibility, which makes accurate policy tuning difficult and largely based on assumptions
Hello Nadia,
Thank you for taking time to register your improvement idea!
We will carefully review it and as soon as we have updates in this way, we will inform you.
Kind Regards,
Simona
Hi Nadia,
I just wanted to inform you that your feature request is still valid on our desk but due to our current full agenda, a slight delay might be experienced in providing a conclusion.
We will get back to you as soon as possible on this one. We appreciate the patience!
Kind Regards,
Simona
Hi Nadia,
Thank you for your patience while we reviewed your request!
As part of our mid-term roadmap, we are planning a redesign of our reporting and dashboard capabilities in the second half of the year, with the goal of delivering enhanced value and improved user experience. During this phase, we will carefully review and consider your request as part of the overall evaluation process.
We appreciate your input and the opportunity to align our future improvements with your needs.
All the best,
Simona
