AIC should export the NT Account
When reconciling the list of owners, the “display name” is useless and not globally unique variable. As well, the import function explicitly calls for the NT Account and adding new subfolder owners would be simpler to base off an export listing. The NT Account needs to be included in the export.
A lot of manual mapping or going directly to the database instead of depending on the reporting system that Netwrix developed.
Hi Philip, I just ran across your idea post here and I may have a solution for you. While I am not able to gleam from your post what report type you’re exporting from the AIC for importing resource owners, for most report types that involve either Active Directory audits or file system audits, we can include additional columns in the report by right-clicking on the column headers and checking the box next to the field(s) you would like to include.
For example, to include the NT Account in a report simply right-click and check the box for “Trustee Account”.
Please note that any fields you add will only be included in that specific report type and would only be included for the account that added the field. You would need to perform this on any other desired reports, as would any other users that may be performing these exports. This setting is persistent however, so it doesn’t need to be done every time you run a report.
