ADV-2025-016 - Hard-coded Password in High Availability Configuration for Netwrix Privilege Secure for Access Management
Executive Summary
A vulnerability was identified in Netwrix Privilege Secure for Access Management when operating in a high availability (HA) active/passive configuration. In this configuration, a default password is used for database authentication of the replication connection.
While Netwrix is unaware of any current exploitation of this vulnerability, all Netwrix Privilege Secure for Access Management customers operating in a high availability active/passive configuration are advised to apply the available update and follow the updated configuration procedures immediately.
Acknowledgements
We thank Tomasz Wasiak from PFR Operacje for his coordinated disclosure of this vulnerability and his effort and partnership in improving the security of our products.
Vulnerability
Title Affected Component Affected Versions CVSS 4.0 Score CVSS 3.1 Score (Base / Temporal) Description
Hard-coded Password in High Availability Configuration (CVE-2025-32361) Netwrix Privilege Secure for Access Management <4.2.1632 7.1 7.1 / 5.9 The Netwrix Privilege Secure for Access Management high availability active/passive configuration uses a default password for authentication of the database replication connection. This may allow an attack to gain unauthorized access to database contents via write-ahead logs.
Exploitability
Factors such as whether details about the vulnerability are publicly known, whether an exploit is readily available, or whether adversaries are actively exploiting the vulnerability are valuable in making risk-based judgments about urgency and priority; customers should use the information below in making those decisions.
Title Publicly known? Exploit available? Actively exploited?
Hard-coded Password in High Availability Configuration No No No
Solution
All Netwrix Privilege Secure for Access Management customers using high availability active/passive configuration are advised to apply the available update immediately. This update is essential to remediating risk from the described vulnerability.
The update is available in the Netwrix Customer Portal, and will apply relevant updates to the application to remediate the vulnerability described in this document.
Post upgrade steps to complete the remediation of the vulnerability and reinstate High Availability can be found in the release notes for Netwrix Privilege Secure for Access Management 4.2 Hotfix 8.
Please contact the Netwrix technical support team should you need assistance.
Official Fixes
Updated software has been released containing official fixes for the vulnerability as indicated in the table below.
Title Version
Hard-coded Password in High Availability Configuration (CVE-2025-32361) 4.2.1632
FAQ
  1. How do I determine which version of Netwrix Privilege Secure for Access Management is in use?
    Version information is displayed at the bottom of the Netwrix Privilege Secure for Access Management login page.
  2. Are deployments of Netwrix Privilege Secure for Access Management which do not use High Availability configuration affected?
    No, this vulnerability only affects customers using High Availability active/passive configuration.
  3. Are deployments of Netwrix Privilege Secure for Access Management which use High Availability active/active configuration affected?
Revisions
Revision Date Description
1 2025-07-17T12:00:00Z First published
2 2025-07-17T15:00:00Z Updated to clarify that only HA active/passive configuration are affected
Disclaimer
An update was made to this advisory.
