Executive Summary
A weakness exists in the way Netwrix Endpoint Protector’s Enforced Encryption module derives as encryption key based on a user-supplied password. Due to insufficient computatational complexity in this process, an attacker with access to an encrypted USB device could potentially gain access to the encrypted content by performing a brute-force attack on the user’s password.
Vulnerability
| Title | Affected Component | Affected Versions | CVSS 4.0 Score | CVSS 3.1 Score (Base / Temporal) | Description |
| Insufficient Computational Complexity in Key Derivation in Netwrix Endpoint Protector | Netwrix Endpoint Protector | <= 5.9.4.1 | 5.3 | 6.0 / 5.2 | An attacker with local access can attempt to perform a brute-force attack to recover the data encryption key. |
Exploitability
Factors such as whether details about the vulnerability are publicly known, whether an exploit is readily available, or whether adversaries are actively exploiting the vulnerability are valuable in making risk-based judgments about urgency and priority; customers should use the information below in making those decisions.
| Title | Publicly known? | Exploit available? | Actively exploited? |
| Insufficient Computational Complexity in Key Derivation in Netwrix Endpoint Protector | No | No | No |
Solution
All Netwrix Endpoint Protector customers are advised to update Endpoint Protector to version 5.9.4.2 or later as soon as possible by following the instructions referenced in the section What’s New in Endpoint Protector 5.9.4.2.
Please contact the Netwrix technical support team should you need assistance.
Official Fixes
Updated software has been released containing official fixes for all listed vulnerabilities as indicated in the table below.
| Product | Release Version |
| Netwrix Endpoint Protector | 5.9.4.2 |
FAQ
How do I determine the version of Netwrix Endpoint Protector is in use?
Please refer to this knowledge base article.
Revisions
| Revision | Date | Description |
| 2 | 2025-04-03T16:00:00Z | Updated solution instructions |
| 1 | 2025-04-03T13:00:00Z | First published |
Disclaimer
