Add "Run Once" per user, not only "per user, per device" (especially for VDI)
Run Once Triggers are not per user. It is run on every “new” desktop for this user.
We know that run once per user, per device is default GPO behaviour as it seems the relevant GPO history is not located in the users profile.
For non-persistent VDI environments every login is a new machine, which results in “run once” is run for every login.
For example it is not possible to assign an FTA like .pdf only once to users to let them decide for themselves afterwards.
Can you implement “real” run once, maybe even to let Admins decide if it should be “per user” or “per user, per device”?
I know there are workarounds which I used many times, but its not that easy in every case like FTA.
For big environments it would also blow up the already huge configuration set and impact login performance even more.
Please also see case 00459338
Where possible we are using scripts to check if its already run using a reg-key or file.
Hello Levin. This task has been added to the Portal and will be discussed with the development department.
Hi Pavel
Thank you for letting me know.
