Add DPI Support for SmarterMail Email Body Inspection and Blocking
Endpoint Protector Server
Extend Netwrix Endpoint Protector’s webmail DPI inspection to detect and block sensitive data in the body of outgoing SmarterMail messages based on Content Aware Protection policies.
During our POC, Endpoint Protector successfully blocked sensitive attachments in SmarterMail webmail with DPI enabled. However, a test email containing more than six NRIC numbers directly in the message body was sent successfully.
We request support for inspecting outgoing SmarterMail message bodies in the browser, including messages sent without attachments. The inspection should apply the configured Content Aware Protection rules, including match thresholds and actions such as Report Only and Block & Report.
This would allow customers to enforce the same sensitive-data policy whether users attach a file or type or paste the information directly into the email body.
We use Content Aware Protection to block sensitive attachments in SmarterMail webmail. We currently have no validated EPP workaround for blocking sensitive data entered directly into the message body in the tested environment.
Hi Sharnitha,
Thank you for your request. SmarterMail is a webmail accessed through the browser, so it’s already covered by DPI. However, reading the email body requires a dedicated parser for each webmail, so the EPP client can understand the content. Such parsers already exist for other webmails like Gmail and Yahoo. We’ll review with the wider team whether a parser for SmarterMail can be added, and we’ll let you know here when we have news.
Thank you,
Zoran
