Active Directory
- Fixed Kerberos and LDAP Bind activity reporting issues introduced by the 2026‑04 Microsoft updates on Windows Server 2016-2022.
NetApp
- Fixed an issue where the OK button remained unavailable when trying to disable the “Enable and Connect” option, preventing users from saving configuration changes. (Case 00473172)
- Fixed an issue where upgrading from an older version could result in “A stream operation requires a corresponding file operation” errors. The upgrade process now automatically disables stream operations when their required matching file operations are not configured. (Case 00473172)
SQL
- Fixed an issue where certain database schema modification operations were incorrectly logged as unrecognized expressions instead of being properly classified.
Included Module Versions
- Active Directory Module -7.5.0.292
Need help with this update?
| Situation | Action |
| If you have a question you’d like to ask other experts… | Create a discussion in the community: Activity Monitor > Discussions & Questions |
| If you have a feature request… | Let our product team know directly: Activity Monitor > Ideas |
| If you have something cool to show… | Show everyone what you built: Activity Monitor > Show & Tell |
What are your thoughts?
