Ability to select multiple monitoring plans when subscribing to reports in Netwrix Auditor
There should be the option to select all, or multiple, monitoring plans when subscribing to a report within Netwrix Auditor
We have over 100+ file server monitoring plans and do not have the ability to select them all when creating subscriptions. It is not feasible to create 100+ subscriptions just to capture the data we are looking for.
This is currently not doable unless we were to create 100+ subscriptions which would then lead to merging 100+ excel documents together just to be able to view and address the data we are looking for. This would take countless hours and is just not worth the time without having this feature.
