Admin policy / organisational setting to require sealing when creating a new password (force seal on create).
Problem
In Netwrix Password Secure (we are on 26.9.100.34193), seals provide strong multi-eye control before a password can be viewed. However, there is no native admin policy that forces users to apply a seal (or seal template) when creating a new password.
Today, sealing depends on:
User discipline after save
Manual use of seal templates
Custom workarounds (scheduled SDK/API jobs that seal unsealed records after the fact)
That leaves a gap: newly created passwords can remain unsealed until someone remembers to seal them or an external job runs. For privileged / shared credentials, that window is a compliance and security risk. Seal templates help consistency, but they do not enforce “must seal on create.” System tasks in current versions also do not include auto-seal-on-create.
Why this belongs in the product
A built-in policy would:
Make dual-control the default, not optional behaviour
Remove dependency on custom API jobs / cron
Align create-time behaviour with how many organisations already treat “sensitive vault entries”
Work consistently for Client and Web Application
Still allow flexibility via seal templates (who is sealed, who may release, multi-eye rules)
Proposed solution
Add an organisational / global / OU-scoped setting, for example:
“Require seal when creating passwords”
Off / On
Optional: mandatory seal template (dropdown)
Optional: scope by organisational unit, form type, or tag
On save: user cannot complete create without applying the required seal/template (or seal is applied automatically from the selected template)
Related UX options worth considering:
Hard enforce — block Save until seal/template is applied
Auto-apply — on Save, apply default seal template defined for the OU
Warn-only — allow save but flag/notify admins (weaker; prefer 1 or 2 for regulated use)
Inheritance should follow existing OU / settings patterns so admins can require seals for shared/privileged OUs and leave personal OUs optional.
Value
Stronger default security posture
Cleaner audits (every new shared password starts sealed)
Less custom integration to maintain
Complements Logbook events (Seal request / reaction / broken) and SIEM (e.g. Syslog → Exabeam)
1.Process — train users to apply a seal template after create (not enforceable).
2.Seal templates — standardise how seals look, but not that they must be applied.
3.Custom automation — scheduled job using the .NET SDK (SealManager.AddSeal + seal templates) that finds unsealed passwords in target OUs and seals them after the fact.
Drawback: residual unsealed window until the next run
Drawback: extra service account, hosting, monitoring, and upgrade risk
We would prefer a first-class admin policy / OU setting (or create-wizard enforcement) so this does not require custom code.
BR
Gowtham Reddy Eeda
