Replacing “No-Connection-Required-” in credential names by a flag within credenital settings.
A typcial error message regarding stored credentials is “Failed to discover platform details of remote device”. To prevent Change Tracker agent to perform first an OS discovery check before trying perform remote login it is necessary to add the string “No-Connection-Required-” at the beginning of credential name. Better solution will be to add a flag/checkbox setting for credentials like “Discover platform details = Yes/No”. Granular explanation about this setting will be helpful too. Why does Change Tracker agent need to discover the agentless platform first? Why does it fail in some cases? As in all failing cases, the only provided solution was to add “No-Connection-Required-” to credential name, I am wondering why the platform discovery is required at all?
Each renaming of a stored credential requires to modify agentless devices by selecting the new named credential. Currently we are using naming convention for stored credential to better find the correct one. A name of a credential should be just a text field and not result in different handling of credentials.
