PHP2Shell on EPP Servers: Test Results Show Legacy Versions
Backend Security Updates Results by EPP Server Version (2026-10-26)
PHP2Shell (CVE-2026-109618, CVE-2026-109619)
Summary
EPP Server Version Installation Image PHP (Before → After) PHP2Shell Status
EPP 5810 – 5942 epp5810-64-mainline.iso 5.2.17 → 5.2.17 (unchanged) Vulnerable – cannot be fixed by update
EPP 2510 – 2604 ubuntu-epp-packer-428726.vof 5.6.40 → 5.6.40 (unchanged) Vulnerable – cannot be fixed by update
EPP 2608 ubuntu-epp-packer-570454-v2608.0.1.0.ovf 8.5.4-0_0ubuntu1.2 → 8.5.4-0_0ubuntu1.5 Fixed
Hello,
Regarding the PHP runtime vulnerabilities disclosed on October 21, 2026, known as PHP2Shell (CVE-2026-109618, CVE-2026-109619, CVSS v4.0 9.2), we have verified the results of applying Backend Security Updates on each EPP server version.
[Findings]
  • EPP 2608: After applying Backend Security Updates, PHP was updated to 8.5.4-0_0ubuntu1.5 and the vulnerability has been resolved.
  • EPP 5810-5942 (PHP 5.2.17) and EPP 2510-2604 (PHP 5.6.40): The OS, kernel, MySQL and other packages were updated, but the PHP version remained unchanged. On these versions, PHP is installed as a separate custom build rather than as an Ubuntu package, so it is not updated through apt-based updates. In addition, PHP 5.x has already reached end of life, and no official security patches are available.
In short, customers running legacy EPP servers currently have no way to remediate the PHP vulnerability through updates, and reinstalling with EPP 2608 is the only fundamental solution. However, it is not feasible for all customers to reinstall immediately.
[Request]
We fully understand that producing security patches for end-of-life legacy PHP versions is outside Netwrix’s scope of responsibility.
However, until legacy EPP servers can be reinstalled with EPP 2608, customers need a temporary measure they can realistically apply. Rather than patching PHP itself, we kindly ask you to provide mitigation or workaround options that block the attack vectors of this vulnerability or reduce the risk, as follows:
  1. A PHP2Shell mitigation guide (methods applicable to legacy EPP servers, such as web server and PHP configuration changes and access restrictions)
  2. A mitigation patch for legacy EPP servers (not a PHP update, but a patch that applies temporary measures such as blocking the attack vectors)
Thank you for your support.
Hi @JeremyG,
Thank you for raising this. As stated in Netwrix Security Advisory ADV-2026-021, we have listed the status of the php2shell vulnerability for each Endpoint Protector version.
We understand that migration requires time and effort, especially in production environments. However, for on-premises customers, the only supported way to remediate is to migrate to the latest 2608 image and keep the backend security fixes up to date. In addition to the php2shell fix, it contains a number of other security fixes and improvements delivered in previous versions, which are listed in the earlier Security Advisories.
We recommend that customers plan and complete the migration as soon as possible.
Please also note that version 5.9.4.2 and older has already reached end of life and no longer receives updates.
If you need help with the migration, please contact Netwrix Support.
BR,
Krzysiek
The two rows in that table measure different things, and the difference comes from how PHP is delivered, not from the update mechanism itself.
On the legacy images (5810-5942, 2510-2604), PHP is a bundled custom build, so Backend Security Updates can bring the OS, kernel and MySQL packages current but have no PHP package to replace; the runtime stays at 5.2.17 / 5.6.40 no matter how often you run them. On 2608 the PHP runtime is part of the packaged stack (8.5.4-0ubuntu1.x in your results), which is why the same procedure moved it to 8.5.4-0ubuntu1.5 there and cleared the check. So “apply backend security updates” is maintenance of the running image, while “move to 2608” replaces the image; only the second puts you in a position where updates can keep the PHP runtime current afterwards.
What Netwrix has actually confirmed: ADV-2026-021 (first published 22 October 2026, no revisions since) lists affected versions as <=2608 (PHP < 8.2.35), and its fix table names 2608 (PHP 8.2.35). The on-premises section says 2608 customers apply the security updates, and older appliance versions are directed to migrate to the latest release first and then apply the updates, using the migration guide on docs.netwrix.com. The advisory publishes no mitigation guide and no mitigation patch for the legacy builds, so both items requested in the first post remain open.
What is still unanswered is compatibility: neither the advisory nor the Netwrix reply in this thread says whether a 5.x- or 2604-era deployment can actually be moved to 2608 on its existing platform, which source versions are supported for that migration, or which PHP line you end up on afterwards. That belongs in writing from support, because it decides whether “migrate, then update” is an executable plan or only a recommendation. One detail to raise with them: the 2608 image here reports 8.5.4-0ubuntu1.x against an advisory baseline of 8.2.35, so it is worth confirming the supported PHP line for 2608 rather than assuming the advisory string matches what ships.
For the audit trail, record the runtime version per server (php -v or the package version) rather than the EPP release number; that is the value the advisory’s affected-version field actually describes.
