Unable to activate CAP trial if customer is in airgapped environment
there used to be an offline CAP activation patch to activate CAP trial in offline environment. the existing CAP Patch does not work in EPP 5209/5210 anymore.
Needs to create a systembackupV2 from an old server and import over to the new EPP 5209/5210 which new customers will find it troublesome.
Great news! We would like to inform you that this has been registered on our side and our team is working towards a CAP Offline Activation Patch for air-gaped environments which is compatible with the latest server versions.
I am writing to inform you that the item has been marked as completed. The Offline Activation Patch for Content Aware Protection and eDiscovery modules, is now available to be applied on air-gapped environments.
In order to obtain it, please reach out to our Netwrix Support Team and they will help you with it.
