Not require Global or Exchange Admins for M365 Connectors
Currently, to setup the Entra ID connector it requires Global Administrator or Exchange Administrator permissions. Requiring Global or Exchange Administrator is a very high level of access and poses a potential security request for customers. If the integration only needs to retrieve logs, a Global Reader role would be more appropriate.
There is currently no workaround, Global Administrator or Exchange Administrator is required.
That distinction should be explicit in the connector design. Document the exact delegated and application permissions the service principal uses at runtime separately from the temporary role needed to register the app and grant tenant-wide consent. Microsoft’s current guidance says Privileged Role Administrator can consent to apps requesting any API permission, while Cloud Application Administrator or Application Administrator cannot consent to Microsoft Graph application permissions. After consent, no standing admin role should remain unless an API genuinely requires it. A permissions manifest and a setup-only versus runtime matrix would let customers validate least privilege without assuming Global Reader can satisfy every required Graph scope.
