Integration with ManageEngine ServiceDesk
Which version of Privilege Secure do you have?
Privilege Secure AM
Validate the ticket number provided by the user when submitting a privileged access request that is subject to an approval workflow
Our requirement is to use the integration to validate the ticket number provided by the user when submitting a privileged access request that is subject to an approval workflow.
Ideally, the PAM solution should be able to:
receive the ticket/reference number entered by the requester;
verify that the ticket exists in ManageEngine ServiceDesk Plus;
optionally verify that the ticket is in an appropriate status and/or contains the relevant requester or other required information;
allow the PAM approval workflow to proceed only if the ticket validation is successful.
Actually unsolved. Reviewer
Awesome to see someone else uses Service Desk Plus! We also use the product and I agree, this would be a nice integration. That being said, it’s totally possible to achieve this by using a custom Powershell step as the first step in your activities. The ticket number is exposed to the custom Powershell step and can then be used to build out whatever integration you could imagine! It’s been an item on my to-do list for quite some time to build out this exact integration for our department, but unfortunately I have not had the time to get after it. If I manage to beat the Netwrix team to building this out through a custom Powershell activity step, I’ll be sure to share!
