EPP Client and Certificate Deployment vis Active Directory
We have a significant number of EPP clients to install. We decided to do it via active directory by pushing the msi packg, thats something we can do. However we have been facing server connectivity issues without also installing the netwrix certificates. Is there any documentation or steps that we can follow to successfully deploy both the epp client and the certificate?
We have a significant number of EPP clients that need to be installed across our environment. We have decided to deploy the EPP client through Active Directory by pushing the MSI package, which is something we can manage internally.
However, we are experiencing server connectivity issues when the Netwrix certificates are not installed alongside the EPP client. Could you please provide any documentation or recommended steps for successfully deploying both the EPP client and the required Netwrix certificates through Active Directory?
The agent obtains its own client certificate from the server automatically as soon as it first connects, so no separate certificate is normally needed on Windows.
To help us pinpoint the issue, could you please answer the following:
  1. Was the MSI downloaded from the EPP server’s Client Installer page (System Configuration → Client Software) or from the Netwrix portal? If it was downloaded from the EPP server was the name changed after the download?
  2. Is the EPP server using the default certificate or a custom/internal-CA certificate?
  3. Which certificate did you install? Please share its file name, issuer, and the certificate store you placed it in if possible.
Client logs would be very helpful as well, but that has to go through the proper support channels.
Thank you,
Zoran
