why can I suddenly uninstall EPP as a local administrator without a password?
I set exactly these settings and restarted EPP.
My policies work—devices are being locked.
What I also noticed is that on the client the Administrator information is blank, even though it’s stored in EPP.
Since the administrator information is blank on the client, the endpoint likely has not synchronized the latest policy from the server, or the uninstall protection setting did not save properly in the console.
Check the EPP management console to ensure the tamper protection and uninstall password flags actually saved and are assigned to the target policy profile. Then, verify client-server policy synchronization so the endpoint pulls down the updated configuration. Once the agent updates and reflects the administrator details, the uninstall password requirement should be enforced.
In some situations the uninstall password is not enforced on the current version. A fix is included in the next release later this month. Support might be able to manually apply the fix if you need it sooner, so feel free to reach out to them.
