Entra ID Monitoring Plan Capture Privilege Escalation
Audit logs from entra should log privilege escalation in the entra id monitoring plan
Tracking outside vendors accessing our environment we need to see what they are doing and when.
Downloading audit logs in the azure portal
Hi Matthew Sailor, thanks for the idea. To make sure we capture the right thing, could you clarify a few points?
  1. By “privilege escalation”, do you mean
    (a) vendors activating eligible roles through PIM,
    (b) any role assignment changes (permanent or eligible, including via groups),
    (c) both?
  2. How do you identify “outside vendors”: guest (B2B) accounts, a specific group, or partner/GDAP relationships?
  3. Do you use Entra ID P2 / PIM in your tenant?
  4. Which specific events do you currently look for in the portal audit logs? An example of a filter or an event name would help a lot.
Thanks, this will help us scope the request properly.
Evgenii
