Best Place To Check Installation Problems
Hey all,
Very simple issue, I’m installing a Netwrix Auditor instance with a Netapp fileshare on a Win 2025 Server, I’m with a relatively small company, so I have no one really to confer with about this.
When installing, I’m getting:
Cannot start auditing the ‘’ server.
Cannot connect to file server (0x80190001 Unexpected HTTP status code)
A KB article is linked as well, but it doesn’t include the event ID, which in this case is 6180.
I have no idea where to look when it comes to the finding more information about this, Netapp is reporting no issues at all, I need to see what is possibly blocking the connection. Is there a log file location that is more verbose? It seems like I’m the first person to ever experience this as the event log ID is nowhere to be found online.
I have shared the certificates between Netapp and this local server, I’ve adjusted firewall rules, I’ve attempted to use Postman to contact the server and inspect the HTTP code, looked inside of Event Viewer, nothing.
Any suggestions on where to go next? I would GREATLY appreciate the help!
Thanks in advance!
Hi @Dawza,
Thank you for flagging this and I have good news for you here.
We are currently improving data collection from NetApp devices and, in particular, we are going to replace “Unexpected HTTP status code” with a more clear information about difficulties the collector faced with. In the current release, many things may cause this message. The plan is to deliver the improvement in the next 10.9 update, and I do hope it will help in your particular case to figure out.
Thanks,
Andrey
Hey @AndreyI
I appreciate the time you’ve taken to reply, and thank you for the information!
I hope to see the update soon, the additional diagnostic data would be fantastic to use.
For the time being, are there any current steps that I could follow to troubleshoot this at the moment or look more into what could be going on?
Thanks again!
Hi @Dawza,
As mentioned, there could be lots of root causes. Hard to say for sure what is your case not being able to see product logs and collect some details on your environment. I guess you could raise a ticket for our support so that we could suggest what to do more specifically if that makes sense.
Thanks,
Andrey
