Apply permission template retroactively to individual existing passwords
Hello everyone,
how can the permissions of a template be transferred to a single existing password?
The background is changing responsibilities and many permission groups from different teams—for example, expanding Development to include IT Security and Infrastructure.
I know the manual adjustment via permissions, but it’s rather cumbersome.
I’d like to avoid a global change of all passwords.
It would help if I could apply a template to an existing record, the same way it’s possible when creating a new one.
I’m missing the following feature for existing records:
Hello @netwrix Team ?
Unfortunately, that doesn’t exist. It would only be possible via an API…
Hi everyone,
Thanks for the feedback. The problem is easy to understand: when, during creation, the wrong rights template or group is selected, fixing it afterwards can be a real hassle.
In the WindowsClient, you can apply a rights template in the Rights window of a selected entry. For multiple entries, there’s also bulk editing, and by using inheritance from organizational units, you can adjust permissions for all passwords in a unit. Which approach fits you best depends on your permissions structure. If you need help with that, feel free to contact our Support—we’ll review it with you.
And if you’d like the rights template to be available in the WebClient as well, you can submit the idea in the Password Secure > Ideas category. Other customers can vote on it there.
Best regards
Kristina
