Benefits of enabling DPI for ChatGPT
I would like to ask about the advantages or disadvantages of enabling the checkbox for ChatGPT under the DPI settings.
We currently do not have DPI for ChatGPT enabled. However, unauthorized file uploads attempted via the installed windows application are still being blocked.
So, what benefits would we gain by enabling DPI for ChatGPT? Inspection of text input?
Thanks in advance!
Hi EDV,
Indeed, DPI allows the agent to scan the prompt the moment it’s submitted and report/block it if sensitive data is detected.
Thanks,
Zoran
Hi Zoran,
ok thank you for the info. So if we do not have the need to inspect the text-input, then there is no advantage for us by turning on DPI, correct?
BR
Hi EDV,
That is correct. If you only want to scan file uploads to the ChatGPT application, that works without DPI, so you can leave it turned off.
Best,
Zoran
perfect, thanks for the info!
