Adding Yubikey USB key serial numbers
The serial numbers of Yubikey USB keys should be recorded.
Hello,
To enable traceability of Yubikey usage, it would be advisable to record the serial number.
Currently, this field is empty in the application.
Best regards.
By running a script at login to retrieve the Yubikey’s serial number and logging it into a CSV file.
Hello Guillaume,
I hope you are well.
Hello,
Thank you for taking the time to submit this feature request and for the detailed context you provided.
We have registered this with our development team for investigation. Once we have more clarity on a timeline or solution, we will follow up here to keep you informed.
Best regards
Cristi
