Advisory: memory leak in Netwrix Threat Prevention agent 8.1.0.48
Severity: High
Last updated: October 23, 2026
Summary
Netwrix has identified a memory leak in Netwrix Threat Prevention agent version 8.1.0.48. The leak can cause excessive resource consumption on domain controllers and may result in service outages. A fix is in testing, and this post will be updated when it is released.
Symptoms
Affected domain controllers show steadily increasing memory and CPU usage over time, which can lead to degraded performance or unresponsiveness.
Affected and unaffected versions
Affected: Netwrix Threat Prevention agent 8.1.0.48.
Not affected: Netwrix Threat Prevention agent 8.0.0.100 & 7.5.0.327
Customers currently experiencing the issue
Open a case with Netwrix Support for assistance.
Contact Netwrix Support
Customers running the 8.1 agent
Netwrix recommends rolling back all agents to version 8.0.0.100. This version is compatible with the 8.1 Enterprise Manager, and no Enterprise Manager changes are required. If needed, contact Netwrix Support to plan and complete the rollback.
Download agent 8.0.0.100
Customers who have not upgraded to the 8.1 agent
Remain on version 8.0 and ensure all agents are running 8.0.0.100.
Update history
October 23, 2026: Initial publication.
November 2, 2026: Fixed in Netwrix Threat Prevention agent 8.1.0.53 as described in this announcement.
